Array Interpolation
hello!I have an array ,Assuming it has 100 values,it's Arbitrary, I want to insert values:
After two each in the array values to insert a value, such as 0 ,This has been the cycle continues until the end, Then get a new array,how should I do ??
Spoiler
Message 1 of 8
(4,452 Views)
Seems like a very simple problem. What have you tried so far?
Message 2 of 8
(4,432 Views)
Hi dfaweew,
 You can insert those values into an array if you can make use of "Insert into Array" vi .
 Please find the attached solution.
Regards.
SrikrishnaNF
Srikrishna
Message 3 of 8
(4,431 Views)
Please don't attach "solutions" until you have tested them. You code makes absolutely no logical sense. Ever heard about shift registers?
Message 4 of 8
(4,422 Views)
Accepted by dfaweew
 As a first step you need to describe the problem much more accurately.
If you have an array with 100 elements, do you (1) want to replace every third element with zero, keeping the array size constant, or do you  (2) want to insert extra elements, making the final array 50% larger?
Here's a simple draft for case (2).
Message 5 of 8
(4,412 Views)
Hi dfaweew,
 I am so sorry as i have posted a wrong solution...I just posted another screenshot of block diagram.
 Hope this helps you..
SrikrishnaNF
Srikrishna
Message 6 of 8
(4,398 Views)
 You are doing this way too complicated! It also looks very inefficient with the repeated array resizing operations.
Now try to do the same with 10% of the code!
(also please attach the actual VI instead of pictures. we cannot run pictures)
Message 7 of 8
(4,391 Views)
thank you,i got it!
Spoiler
Smiley Happy
Message 8 of 8
(4,375 Views)
