Arrange Array in ascending order by date
Kindly help me sort out the order by problem.
I have a date array which goes like;
12/3/2012
11/3/2012
12/5/2012
12/8/2012
12/6/2012
12/12/2012
12/10/2012
12/17/2012
I need to arrange it in ascending order, like
11/3/2012
12/3/2012
12/5/2012
12/6/2012
12/8/2012
12/10/2012
12/12/2012
12/17/2012
Please help.
Thank you in advance.
Regards
Grugh Mike
Success is Everything !!
Message 1 of 25
(7,953 Views)
Hi
I believe you have an array of strings. Use the Sort array function available in the Arrays palette. that should sort the array in ascending order as you wanted.
I missed one thing. when you sort it, you would get 12/17/2012 before 12/3/2012.
hmmmm...
Regards
Freelance_LV
TestAutomation Consultant
Message 2 of 25
(7,952 Views)
sort array by ascending or decending does not give as required.
It gives out the result in a jumbled manner.
Regards
Grugh Mike
Message 3 of 25
(7,949 Views)
i realized it a bit before you replied.
anyways, can you post your code in LV2010?
Regards
Freelance_LV
Message 4 of 25
(7,946 Views)
Convert the time to second and then use the sort array and then back convert to time stamp.
Message 5 of 25
(7,945 Views)
There is a work around, i was looking for in the forums
since you have the dates and not time (sicne you did not say anything about time),
http://forums.ni.com/t5/LabVIEW/time-date-string-to-timestamp/m-p/1644284/highlight/true#M590419
refer to the link below. convert the string time to timestamp. you can use a constant time with all values.
then covnert the timestamp to double number, sort the array in ascending order.
then convert the numeric time value to string and extract only the date info.
Regards
Freelance_LV
Message 6 of 25
(7,944 Views)
is'nt there any easier method to sort a time array ?
Regards
Grugh Mike
Message 7 of 25
(7,940 Views)
This is one of the method to sort the array.
Message 8 of 25
(7,931 Views)
It's a lot easier than trying to manipulate the strring into yyyy/dd/mm format and sorting alphabetically.
Bill
CLD
(Mid-Level minion.)
Message 9 of 25
(7,886 Views)
Well that sort of depends, if the code that generates the timestamp in the first place is under your control, just generate it in that order to begin with.
Certified LabVIEW Architect
LabVIEW Champion
Message 10 of 25
(7,883 Views)
