Arduino with LabVIEW
I have an optical pulse sensor which is connected to arduino, thus it gives an analog output. Is it possible to interface it with LabVIEW such that I will be able to get real time reading in LabVIEW?
Example: Like using DAQ assistant block present in LabVIEW, we get real time reading from NI USB6009.
(2,931 Views)
Hi Sid,
you can communicate with your Arduino and read the values measured by the Arduino…
(There are toolkits available for Arduino!)
Pulse detectors usually provide digital signals…
(2,930 Views)
I suggest you try the LINX toolkit
=== Engineer Ambiguously ===
(2,871 Views)
