Arduino ADC/Serial corrupting data
Accepted by tyar97
@tyar97 wrote:
I am trying to set the protocol but I am stuck.
Did you implement the protocol on the Arduino?  You should have something similar to this:
byte sum = byte(val[0] >> 8) + byte(val[0]) + byte(val[1] >> 8) + byte(val[1]);
Serial.write(0x2); //Send sync byte
Serial.write(val[0] >> 8);
Serial.write(val[0]);
Serial.write(val[1] >> 8);
Serial.write(val[1]);
Serial.write(sum);
NOTE: I am not had the luxury of playing around with an Arduino, so fix any syntax errors I have introduced.
Then on the LabVIEW side, you do something similar to this:
Note: Notice that there are no waits in this VI.  The rate of data coming into the port will determine the loop rate.
Message 11 of 13
(1,016 Views)
Yes, my code is very similar and works fine.
Finally, it seems it works perfect!!
Thank you very much and I really appreciate what you did!
Message 12 of 13
(1,005 Views)
Glad to hear you have it working!
0xDEAD
Message 13 of 13
(996 Views)
