Aquire two analog inputs & How to put in array
Hi
I don't know how to use spreadsheet , Can you please give me a Example .
nitin
Message 21 of 41
(1,791 Views)
Hi Nitin,
open the help for WriteToSpreadsheetFile, and read it.
Once you are through you will find a button "open example" at the bottom of the help window…
Message 22 of 41
(1,786 Views)
Hi Gerd
I tried But nothing is coming in Spreadsheet . Infact .Xls file  is geeting damaged also .
please have a look at attahced VI snapshot .
regards
nitin
Message 23 of 41
(1,776 Views)
Hi Nitin,
there has to be atleast one value in the spreadsheet file…
- Do you know the difference between spreadsheet files and XLS files? LabVIEW writes simple text files containing CSV data. Please keep this in mind!
- When you want to save more than just the value of the last iteration before stopping your loop you might think about putting the save operation into the loop…
Message 24 of 41
(1,773 Views)
Thanks Gerd
I will Ping you Once again .
You are a nice  person .
Smiley Wink
Message 25 of 41
(1,764 Views)
Hello Gerd
Sorry to disturb you again ?
 I have a querry & its regarding Vi snapshot i shared previousley .
You give me a logic for the counter  , is there any block or some function that will do the  task mentioned  in Green  " counter is countinousely counting for the first analog signal  but whenever the slow analog input change from low to high  counter value is captured .How can i capture caounter value when  condition is satisfied ".
Thanks & Regards
Nitin
Message 26 of 41
(1,741 Views)
Hi Nitin,
using light green on light grey backgroudn is kind of hard to read. Use a different color next time… 😉
You need to use the second AI as condition for your counter. Detect rising edges on this signal and whenever you have found one you read the current value of the counter.
 It's a simple IF-THEN condition, quite easy to implement with a case structure…
Message 27 of 41
(1,736 Views)
Hi Gerd
I tried , Please have a look at the Vi  only the final value is written in file instead of the value at trigger point . .
Is it possible to  send these values to excel instead of notepad ?
Thanks & regards
Nitin
Message 28 of 41
(1,726 Views)
Hi Nitin,
You need to program this! Write data to your file when the "trigger point" is reached!
You already write a spreadsheet file so you can easily load the data with Excel. I don't see any call for notepad in your picture…
Why do you count both signals? You said you want to use one signal as a gate for the other one!?
Message 29 of 41
(1,716 Views)
Hi Gerd
I want to count other signal pulse also , so that's why i used two sepertae counters .
Anyways but i am still confused how to write into file when trigger point is reached for this i created the case structure also . It is visible in VI .
For Notepad call , I am doing it in front panel . and i tried to open it in excel . Its working ...
Main concern is the single  counter value is printed ten times .... How to make it one time .
Message 30 of 41
(1,712 Views)
