Aquire two analog inputs & How to put in array
Hi gerd
Thanks.
I will check once again these function s & let you know.
I was just showing refernce for real channel ,  doesn't mean that i was selecting frequency .
I will create a new Vi and then i will  share that with you
nitin
Message 11 of 41
(1,325 Views)
Hello Gerd
I tried to take input from Analog channel but its not compatible with Boolean Crossing.
I attached VI snapshot please have a look.
Message 12 of 41
(1,319 Views)
Ni Nitin,
have you ever considered to create a boolean value from a DBL one by using a comparison function?
Or have you ever considered to use a digital input when your voltages obey TTL logic voltage levels?
Message 13 of 41
(1,311 Views)
Dear Gerd,
Sorry I never tried this things , I told you i am  a beginner ,  just before few days back i started labVIEW before that , i don't know what was labview .
Thanks & Regards
Nitin
Message 14 of 41
(1,309 Views)
Both suggestions aren't specific to LabVIEW, they are either basic measurement or basic programming concepts…
Message 15 of 41
(1,307 Views)
Dear Gerd
Can you please spare few minutes for me and give me the Block diagram , I need for Doing this work ?
I will be thankful to you
Message 16 of 41
(1,324 Views)
I already did the main part, you only need to supply boolean signals…
Message 17 of 41
(1,322 Views)
Dear Gerd
I will try to do this , if not able to make this please help also in making boolean signals from TTL signals
Thanks & regarsd
Nitin
Message 18 of 41
(1,318 Views)
Hello Mr Gerd
Greetings of the day
Finally i am able to count the number of pulses .
I want to store that value in an array . Can you please help me in the same .
I have attached Vi snapshot .please have a look .
Message 19 of 41
(1,281 Views)
Hi Nitin,
use WriteToSpreadsheetFile…
Message 20 of 41
(1,267 Views)
