Approximation of a curve
Hello all. I want generate a curve similar to the image given below and repeat it as cycles. Any thoughts?
Message 1 of 9
(2,686 Views)
You could be looking for a mathematical formula to describe your signal or you could just create a lookup table that you repeat.
(How "similar" should it be? Maybe start with the first derivative of Gaussian or Lorentzian peak?)
Message 2 of 9
(2,681 Views)
Thanks.Gaussian derivative would be better,can I select the curve at a particular region and loop it?
Message 3 of 9
(2,667 Views)
Accepted by topic author Chatla
Yes, of course!
Message 4 of 9
(2,644 Views)
1) I have some data points of graph in excel. I want to generate that graph in Labview?
2)  I have only one cycle of that wave form. After generating that in labview , how do I replicate that into multiple cycles?
Message 5 of 9
(2,510 Views)
Could anyone help me?
Message 6 of 9
(2,483 Views)
Hi Chatla,
  1. Read the data from your Excel file using LabVIEW functions and display those data points in a graph…
  2. Use BuildArray to "replicate" the waveform…
Message 7 of 9
(2,480 Views)
Thankyou for replying, can you please brief about how to read data from excel using labview functions and display it in graph. I am new to Labview.
Message 8 of 9
(2,473 Views)
Hi Chatla,
Are you using real Excel files (XLS* suffix?): use RGT functions.
When you use delimited text files then LabVIEW provides Spreadsheet file functions (aka DelimitedTextFile)…
Did you notice those "Training resources" in the header of the LabVIEW board?
Message 9 of 9
(2,466 Views)
