Application builder problem
I am trying to create installer and I get this error message and compiling is unsuccessful:
______________________
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> IB_MSI.lvclass:Build.vi >> IB_MSI.lvclass:Engine_InitializeDistribution.vi >> IB_MSI.lvclass:Report_Preview_Error.vi >> IB_Source_Container.lvclass:Report_Preview_Error.vi
Loading product deployment information
________________________
(3,782 Views)
Post your VI and project.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,771 Views)
HI,
Are you able to see other installers in a additional installers Tab?
Are you following under mentioned steps?
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/build_installer/
Bijay
(3,758 Views)
Hi Mark, I am was having a similar problem.  I tried taking away all "additional installers" and building the installer again; no luck.  Then I tried renaming my top level VI, moving it from the folder user.lib/Xray to projects/Xray.  The re-built the EXE.  Then created a new installer based on the new EXE.  It worked!
I don't know if this is just coincidence - maybe just trying enough times.  But in the past I have had other troubles with VIs in user.lib, which got fixed when I moved stuff to the projects folder.  (It was the functionality of the "help for this VI" menu option, calling up my documentation.)
Good luck, I hope this works for you.
(3,701 Views)
May I ask why ? Why you removed all the additional installer. Are you sure you dont want any of them.
--Ranjeet
(3,692 Views)
I mistakenly thought that the additional installers might be the problem.  The reason I thought so was, when I was building the installer the first time, it asked me, "please insert the DVD named Device Drivers - Third Qua" and then it was cut off due to lack of space.  I had two DVDs that were Third Quarter of different years.  I tried the wrong one first.  It complained.  I tried the other one.  It proceeded, but, as you know, it had an error at the end.  So naturally I thought, "maybe it was that DVD mixup that killed me."
But no, that was just coincidence, having nothing to do with the real problem.  I added the additional installers back, later, with no problem.
(3,664 Views)
