Application builder-Office report generation toolkit
I remember there was a trick to get the executable work with different
versions of Microsoft office but I cannot find it now. The problem it to get
the exe work with some other office version that it was made. I use LabVIEW
7.0 - 7.1 and Report generation toolkit 1.01 for Microsoft office. Was that
possible?
Thanks Eki
(2,991 Views)
Eki,
When you use the Report Generation Toolkit to build a stand-alone application with the Application Builder, you must add _Word Dynamic VIs.vi from _wordsub.llb and _Excel Dynamic VIs.vi from _exclsub.llb as dynamic VIs. These two VIs contain subVIs that are called dynamically by the high-level Report Generation VIs. I believe that if you grab these VIs from the (desired office version part of the) installation CD instead of from the development machine, then everything should work.
Zvezdana S.
(2,991 Views)
