Application Webservice not working since LV2021(64bit) / LV2020(64bit) was perfect
Hi Community
I still have the same problem even when I use a package instead of an installer.
I have configured the Application as shown here in the screenshot.
in my Package properties I added this project
I also added many additional dependencies to my package installer, to be sure not to miss something.
Finally I still end up with the following errors when starting the application and set the loglevel to 2.
appweb: 2: Configuration for Embedthis Appweb
appweb: 2: ---------------------------------------------
appweb: 2: Version: 4.1.0-0
appweb: 2: BuildType: Release
appweb: 2: CPU: x64
appweb: 2: OS: windows
appweb: 2: Host: DESKTOP-BJEAG83
appweb: 2: Directory: C:\Program Files\IoniTOF 4.4 PKG
appweb: 2: Configure: bit configure --platform windows-x64
appweb: 2: Loading native module C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\2023\mod_nisessmgr.dll
appweb: 2: Loading native module C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\2023\webserver\modules\mod_niauth.dll
appweb: Error: NI Auth Module -- Caught exception while loading NIAuth shared library
appweb: Error: Initialization for module niAuthModule failed
appweb: Error: Error with directive "LoadModule"
At line 15 in C:\Program Files\IoniTOF 4.4 PKG\niembeddedws.conf
appweb: 1: Can't configure the server. Error -19 while parsing configuration.
appweb: 1: Couldn't start LVAppwebInterface
When I start the same installed package on my development PC all is fine and the error file looks like this.
appweb: 2: CPU: x64
appweb: 2: Host: CLIA087
appweb: 2: Loading native module C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\2023\mod_niesp.dll
appweb: 2: Loading native module C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\2023\mod_niws.dll
appweb: 2: Started HTTP service on "*:8002"
appweb: 2: Pruned 1 workers, pool has 0 workers. Limits 0-10.
Do you have any additional ideas how to solve this issue.
Thank you
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
Message 11 of 16
(2,322 Views)
Can you confirm that you are installing on a clean Windows install? If you have run a "broken"  installer before it might be that the package installer will not work. At any rate, there is a dirty workaround for the standard installer. If you configure the Installer Build Spec so as to install on the target PC the following folder present on the development PC:
C:\Program Files\National Instruments\Shared\niauth
Everything will work just fine.
Have a look at my installer specification
Message 12 of 16
(2,316 Views)
You have to do a complete uninstall of all things NI, otherwise the error message sticks around.
Did you make a package installer?  That would work most similarly to the previously supported installer option.
Message 13 of 16
(2,308 Views)
Thank you,
No it is not a 100% clean system.
I will try on wednesday with a absolutely clean one and keep you informed
Gernot Hanel
Message 14 of 16
(2,306 Views)
Dear Igor et. al.
I also can confirm that this "workaround" works on a "naked" PC.
I accepted as a solution.
Thank you once more for the help. You are much better than SSP or what it is called today 😉
Gernot Hanel
Message 15 of 16
(2,269 Views)
The actual reason for this problem is that the run-time installer doesn't install all the files needed for the application webservice to run. This folder is missing even after running the installer - C:\Program Files\National Instruments\Shared\niauth. Copy this folder from your development computer to the target computer or include it in the custom installer and you should be all set. I know this is a stale thread but maybe this will help someone out there!
Message 16 of 16
(2,250 Views)
