Application Broken with error 6208 on a particular PC
Accepted by Fedor
I tested the newly released LabVIEW 2020. It appears the bug was fixed there.
Message 21 of 23
(1,366 Views)
To anyone who ends up here, the solution for me was to find DLL dependencies of the DLL used in my application. LabVIEW does not traverse the DLL dependency hierarchy automatically and will not include the dependent DLLs in the support directory.
Message 22 of 23
(1,182 Views)
My particular case, the build exe would fail with this error but only sometimes. I currently unchecked to "Remove unused " items from the build configuration and now it works. I'll update if this fix doesn't hold up across multiple build iterations.
Sounds like the common element is that something isn't getting pulled into the compile somehow.
Message 23 of 23
(1,053 Views)
