Append data to a table
I am new to LabVIEW. I am working on a program for a project where I need to measure data populate a table when a button is clicked.
Please see attached example VI even though it's not the actual program it explains only a simple part of it that I need help with.
I need to write calculated values ​​​to the 1st and 2nd columns of the table each time when I click on the Read button. Most importantly I need to retain previous values ​​​​in the table and append new values ​​​to the table each time when I click the Read button. Attached VI I created does it exactly the way I want. But I used a local variable to get previous values ​​​from the table to append to new values. I am reading that's not a good practice to do it with a local variable like this. but I can't figure out a different way to do it. could someone explain to me why it's not good to do it with an LV as I have done and what's the best way to do it? Thank you
(1,858 Views)
Accepted by ATX1122
Sorry, I don't have LabVIEW 2021 here, so I cannot see your code, but typically a shift register anchored on the toplevel loop is the way to go.
(1,844 Views)
Accepted by ATX1122
Simplfied, it could look as follows.
(Both buttons are latch action. Other event is for the stop button)
(1,837 Views)
