Append data column wise into binary file
Hello folk,
I need to write 19200000 data into binary file. This data is stored into TDMS file. The file is of 32 channels with 600000 samples for each channel.  Now I need to write binary file with 32 columns and 600000 rows.
Doing this with two dimension array lead me to memory full error. Hence I need to write each channel data as soon as I read without building an array.
Please suggest me how to append this channel data into binary file.
Your help will be truly appreciated.
Thank you
CLAD
Passionate for LabVIEW
(3,411 Views)
Hi Jatin,
do you want to store the data in a TDMS file or in a binary file?
When it comes to problem in using 2D arrays then why don't you save your channels as 1D arrays?
Mind to show a VI to explain the problem?
(3,407 Views)
@GerdW wrote:
Hi Jatin,
I write data into TDMS file in my RT code. Now I need to convert this file into binaray file. My channels are saved in 1D array format. Since I have 32 channels and for better observation I want to convert .tdms file to binary file with every column having 600000 data.
First I made a code with 2D array format. It works fine but for lesser samples. With raised requirement I need to go with 1D array.
I have attached a code with 2D array format.
CLAD
(3,397 Views)
Hello GredW,
Thanks for your concern.
Here is my upgraded code too with 1D array format. But it writes data into 1 column only.
CLAD
(3,388 Views)
