Append Frontpanel Image to Report Bug?
The FP image appended to the report doesn't fit on the page.
i tried changing the Size of the front panel but doesn't help. i hope the default boarder size is 1,1,1,1. please find the attached Vi and report created.
why is it so?
LV2010
Kudos always welcome for helpful posts 🙂
Message 1 of 11
(3,837 Views)
What's missing?  From what I'm seeing, it all shows up.
GCentral
Message 2 of 11
(3,815 Views)
Hi Crossrulz
i tried two different FP resolutions. the Vi and results are also attached.
the second pdf is made with resolution width 683 x height 965.
but the image always leaves some space on the right side of the page. And the width of the image in PDF is automatically adjusted.
thanks
Renn
Message 3 of 11
(3,798 Views)
attached is the LV2010 version
Message 4 of 11
(3,792 Views)
Why the image width is resized? the boarder size is 1x1x1x1. Always the image leaves some space on the rightside.
Message 5 of 11
(3,767 Views)
Can anyone help with this issue?
Message 6 of 11
(3,732 Views)
could you please explain whats missing?
Message 7 of 11
(3,724 Views)
Try to set the alignment to MIDDLE when appending the image.  That should center the picture on the page.
GCentral
Message 8 of 11
(3,708 Views)
thanks crossrulz.
with a png image format i get better quality prints, but still the quality is poor compared to printing VI frontpanel after execution.
Message 9 of 11
(3,680 Views)
html reports
alignment works only with html reports i think. for that i must have IE installed on my PC isn't it?
also i need to set the margins in IE settings also.
Stadard reports
the image is not fitting on the page if i resize the image. is this a bug?
Message 10 of 11
(3,671 Views)
