App failed. Error code 10202003. Unable to lock memory chunk
hi, I have a mobile project with this error:"App failed. Error code 10202003. Unable to lock memory chunk "
it is about sending ECG via bluetooth and detecting R peaks and then finding ST segments. but when i use mobile module, this error appear. what should i do?
(3,004 Views)
It was a while ago but I created an application, and it gave me the same error (I think it was the same - I don't have that number anymore and it was on a different PDA).  I was playing around with my application and was able to get it to work.
What I did between when it worked and when it didn't work:
Reinstalled DAQmx Base support on the PDA (from the project).
Debugged the application (from the project).
These steps might help you get up and running.
(2,957 Views)
maybe I should explain my project better
I have some data from physionet and I send them from laptop to PDA  via bluetooth. and then in the mobile i process the ECG to find ST-elevation.
i can send the ECG and display it in the PDA  but when i add other processing parts,i see this error .
(2,941 Views)
