08-13-2012 12:55 AM
nn
Solved! Go to Solution.
08-13-2012 01:20 AM
08-13-2012 02:00 AM
but how can we use excel to control the labview as a server? can it be done by using tcp/ip also?
08-13-2012 02:17 AM
Pls give an overview of what you are trying to achieve so that you can get proper solution in this forum
08-13-2012 02:37 AM
erm ok i will explain...
actually..i know that labview can be a client or server. when the labview be a client, it can access other enable activeX application such as excel or word. i manage to do that a little such as to open excel file and save it at another location by using activeX functions or using the report generation toolkit. yes, i already know and understand the flow or concept of how the labview can be a client. But by using others activeX application especially excel, how can we make the labview be a server? i just need a very easy example and few steps for me to understand how can labview be a server or how excel can control the labview properties?
really desperate to increase new knowledge.....:-)
thank you very much for helping me....
08-13-2012 02:54 AM
You're confusing client/server with ActiveX. ActiveX is the ability to use functions from other programs, it has nothing to do with client/server.
Just like Excel has made a ActiveX export so can you do e.g. build a DLL for other programs to use.
/Y
08-13-2012 03:20 AM
ohh...i see....erm..thanks for the explanation...really appreciate it....build other DLL for another application?? i'm sorry...i'm a new in this labview world....but i really to advance my understanding in this program....thanks again for your help....may god bless u.....
08-13-2012 10:06 AM
Actually, client/server does apply to ActiveX. To control LabVIEW from another application, you use the VI Server Properties and methods and you do not need to create a dll.
10-26-2012 09:23 PM
hello...now i'm using labview 8.5 for my final year project....i need to know how can i control the temperature sensor, pressure transducer also the load cell? can i convert the graph in VI into excell file by using labview 8.5? relly need help...
10-26-2012 10:28 PM
