App builder error 7
Building an app from a top level VI that uses VIs we wrote and put in an .LLB file, I get "Error 7 occurred at Librarian Get Info.vi-File not found." We have built applications before without this error. The files in the .LLB use a DLL, which is in the same directory as the source VI.
(2,784 Views)
This KnowledgeBase describes the error you are receiving. If you are calling any VIs through VI Server, you must include them as Dynamic VIs in the built. Let us know if, after trying this, you still have trouble with it.
J.R. Allen
(2,784 Views)
