Anybody running LabVIEW 7.0 on a Pentium II?
last year i runned it on a pII computer, but i didn't use it for acquisition, it runned just a simple motor.
Message 11 of 19
(1,368 Views)
Hi Ed,
LabVIEW has supported Multithreading on Multithreaded OSs since LabVIEW 5. At the same time support for Multiprocessing was added.
Please refer to the following link for much more information on Multithreading, Multitasking, Multiprocessing and Hyperthreading:
Multithreading
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 12 of 19
(1,465 Views)
Here is a link to the Matrox G400 Spec.. It seems that they do hardware support for OpenGL. I don't know if the OpenGL library NI uses will make use of it. But if you like and know C you can look at it. The sources are located on your LV installation CD as it is required by GNU public license.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 13 of 19
(1,350 Views)
Philip,
So the development evvironment is dual processor aware and can take advantage it? The question I was trying to figure out is, "Does a dual processor machine help during development, or only when your applicaiton is running(if it's written correctly)".
Ed
Ed Dickens - Certified LabVIEW Architect - DISTek Integration, Inc. - NI Certified Alliance Partner
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 14 of 19
(1,447 Views)
Hi Ed,
You got me! All the documentation I can find on multithreading refers to the running VIs and not the actual Development System. I will have to get an answer from our R&D department regarding this question.
I'll get back with an answer ASAP.
Thinkbot Solutions
Message 15 of 19
(1,330 Views)
I think I'm gonna start a new thread about this.
Message 16 of 19
(1,318 Views)
I'm back with an answer from R&D:
In the LabVIEW Development System everything at edit-time is single threaded and runs in the UI thread. This is chosen because you generally wouldn't get much gain from the editor running in multiple threads, even on a multi-processor machine.
I will create a KnowledgeBase that describes this behavior, in case the question should arise again later.
Thinkbot Solutions
Message 17 of 19
(1,303 Views)
Thanks.
And it's really interesting.
Message 18 of 19
(1,290 Views)
Thanks Phillip,
Another useful bit to file away.
Ed
Message 19 of 19
(1,278 Views)
