Any example code using Generic IVI Scope driver to get an External Trigger from a Scope?
I'm using a LeCroy WavePro 950.
(3,223 Views)
I have done that using a "waverunner" if memory serves me correctly.
Did you check out the driver available for download from this site?
http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/bd22a2bf3d4a5503862569a7007778d7?OpenDocument
I first had to figure out how to get the scope trigger manually. Once I had that figured, I was able to adapt the example to do the triggering.
Hope this helps,
Ben
(3,223 Views)
Hi Ben,
I have the class driver, ni-visa drivers and The specific Scope driver from ni that you have the link to. I can detect the triggers on channels 1 - 4 but if those channels are disabled, can I detect a trigger from the external trigger source only? Do you have any examples?
John
(3,223 Views)
