Any Ideas How I can Make this Formating Program Run Faster?
Yup. I see that. Thanks Matt.
Message 11 of 14
(1,710 Views)
Excuse me...a co-worker of mine just got an *.fvp file and he is wondering what it is for; I don't know either. I googled it and not much show up on it, but this thread...what in the world is an *.fvp file and how can I view it?  I mean, if I open in the text editor, the first few lines look like this:
FVPARTICLES 2 1
Tag Names
0
Variable Names
2
particle id
particle_id
321
-6.92931e-07  -0.0101538  -0.307975  0  0
-6.91972e-07  -0.0101538  -0.306939  0  0
-6.8872e-07  -0.0101542  -0.305844  0  0
-6.79283e-07  -0.0101549  -0.304687  0  0
It is supposed to represent flow lines of some sort...is this a static picture? is it supposed to be some kind of animated image? what can I use to visualize it?
thanks in advance for any pointers.
gsal
Message 12 of 14
(1,635 Views)
fvp is just an extension.  You have a text file.  It looks like the name of the program may be FVParticles, maybe v2.1.  The extension is just an easy way to identify that it is an output file from that program.
It looks like the file has 0 Tag name, and 2 variable names, paricle id and particle_id.
I am guessing the 321 may be the number of data points.
You've got five columns of data.  The last 2 are probably all 0 and can be ignored, as they may be place holders for additional unused variables.  I don't know if the first column is X values or not.
You can use Excel to plot the data.  Import the text file into Excel and then plot the 3 columns of data.  You can try plotting each as a seperate plot on the graph, or use the first column for the X values and the 2nd and 3rd as the y values (this is probably how it is supposed to be done).  If you don't know what the data is, then you will have a hard time knowing if you are plotting it correctly.
Message 13 of 14
(1,625 Views)
Thanks, Mark, for your "insightful" commentary.
With more research this morning, the truth came out...I found the answer in some page of FLUENT user manual (here).  This is a FieldView kind of file, in particular a pathline file.
gsal
Message 14 of 14
(1,597 Views)
