Analog input and output module synchronization, cRIO-9035
I am a student and new to LabVIEW.  I want to build PID controller for my project but before that I need to synchronize two modules which I am using with cRIO-9035. Basically I want to acquire signal with NI 9232(Input Module,24bit) and send it back to NI 9269(Output Module,16 bit).
I have successfully completed this task of acquisition and generation. However I am getting phase shift in the output signal. For further stages of my project , I want signals to be completely or nearly in phase, not much phase shifted.
I have been working on this task for quite long time but not getting where the error is.
Looking forward for the help.
Thank you in advance.
FPGA ViFPGA ViRT MainRT MainRT Main_ContinuedRT Main_ContinuedPhase diagram for sweeping singal(100Hz-3kz),(Green -Input, Red -Output)Phase diagram for sweeping singal(100Hz-3kz),(Green -Input, Red -Output)
Message 1 of 1
(2,564 Views)
