Analog accelerometer ADXL335
Hello everyone!
I'm beginner user of LabVIEW and to be working with an MEMS analog accelerometer ADXL335. I'm using a Hardware USB NI 6008 for acquisition the vibration signals. The images show the simulation disturbance of beats on the substrate.
I have some questions and I need help:
The "Spectral Measurements" shows the signal in the frequency domain with its Harmonicas components (Hz)?
The peak between 0 and 2 (Hz) is the signal DC component and how can I remove it via software?
How can I integrate the signal to obtain amplitude values in speed?
Thank you!
José Ricardo
(4,677 Views)
Welcome to LabVIEW!
I don't know if this is going to help, but I think most of your questions can be answered using LabVIEW Help. Be sure and enable Context Help (Ctrl + H) as it's pretty useful.
1. Take a look at the help for the express VI you're using https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/express/express-analysis/spectral/x...
2. Some of our Filter Express VI's should probably work for you https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/express/express-analysis/filterbloc...
3. The integral functions in the Math palette should be what you're looking for https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/mathematics/dir-mnu.html
All of those links are a bit older I think (from LabVIEW 2011), but you can also find the newer versions just using the help files included with your version of LabVIEW or doing a quick google search.
Hope that helps!
Daniel Parrott
Software Product Marketing - Data Management & LabVIEW
(4,647 Views)
Hello
Thanks you helping me. I was using LabVIEW Academic in the College and this license does not include the filter function. I downloaded the evaluate version on the notebook and it was possible to remove the DC signal with a high pass.
I will study the integration of functions and shared links.
Thank you!
José Ricardo
(4,588 Views)
