09-25-2011 07:38 PM
Lynn,
That is a cool device. I had never heard of that before.
Terry
09-25-2011 08:08 PM
Terry,
I have not driven one of these from a D/A converter, but I have often done this with op amps. I have built current regulators this way.
These devices are robust: So long as you do not put too much voltage (>35 V) on the inputs or omit the required bypass capacitors, they are nearly impossible to destroy by shorting: They just shut down. They are also quite inexpensive and readily available.
With an inductive load like the solenoid, some protective diodes are also recommended.
Lynn
