Analog Output signal stops
Accepted by topic author Innervision
Hello Innervision,
I made as little as possible adjustions to your code to make it working.
Please not that this is not the best architecture for that purpose.
I just wanted to make sure that you understood what is happening.
The next step would be to put your design in a state machine.
After this I would like you to try to learn more about the available DAQ functions next to the DAQ assistant.
The current software wise update of the analog output is not the optimal way to do this.
Also I think that the 1 second time interval is not so optimal.
Please confirm if you understand everything that happens in this VI.
If you do, then we will be able to go to the next step.
The attached Code is provided As Is.  It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments.  You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 11
(384 Views)
