Analog In FPGA Rio
Guys, you need to realize that the 9234 is a DSA device and runs on its own internal clock.  Pacing it with a timed loop DOES NOT work with DSA devices.  Please take a look at the reference designs I linked to in an earlier post.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
Message 11 of 13
(939 Views)
Hi all,
For getting started with DSA modules, you should check out the shipping examples.  They should be ready to go, and have code written for the FPGA to give you a starting place.  To find the exaple, open up the example finder by going to help > Find examples from any LabVIEW window.  Next, go to Hardware Input and Output > cRIO > Module Specific > 923x Continuous DMA.
Cheers.
Ryan
Message 12 of 13
(932 Views)
Thanks for the note Ryan,
The Continious DMA example is illustrative in basic principles.  The Waveform Reference Library builds on these and adds much more:  https://forums.ni.com/t5/Example-Code/Reference-Application-for-NI-CompactRIO-Waveform-Acquisition/t...
It synchronizes the start of acquisition with a time stamp on the RT controller - so you have better t0 accuracy
It increases error handling coverage
It handles varied number of channels on the RT side
It formats the data to a FLOAT on the FPGA side before the DMA buffer - saving 40% of the RT CPU time.  It is expensive to cast from fixed point to float.
Just another helper to consider
Preston Johnson
cbt
512 431 2371
Message 13 of 13
(928 Views)
