Showing results forĀ
Search instead forĀ
Did you mean:Ā
An error occurred loading VI. LabView load error code 1: LabView load error code %ld: %pā€
I have been developing a VI file that has been working fine, until now. I am using 8.6.
Every time I attempt to open this file I keep getting:
How do I fix the error code:
Labview: Memory is full.
On a separate dialog:
ā€œNot enough memory to complete this operation.ā€
I ran VI analyzer which told that the VI:
One or more errors occurred during analysis.
Testing errors tab – Vi not loadable and my file name. At the bottom in the error description I got:
ā€œError 74. Memory or data structure corrupt. <my file path> and <file name>.ā€
Could not be opened.
Is there anything I can do to recover the file?
Message 1 of 8
(8,129 Views)
That KB article applies to when you're running a VI, not when you're opening a VI, which is what the user is having problems with.
To poster: Your most likely problem is that you have a corrupt VI. I would suggest trying to open a backup, which you have, right? You could try to upload your VI to see if someone else can open it.
Message 3 of 8
(8,090 Views)
Hi
Is there an answer for this? i have the same problem...
Message 4 of 8
(7,121 Views)
As I indicated, the VI could be corrupt. Try opening a backup. Otherwise you can upload your VI and see if someone else can open it.
Message 5 of 8
(7,116 Views)
Hi there
I am having this same problem.  I don't have a backup of this code and was wondering if someone could perhaps try to open this file for me.
Message 6 of 8
(6,512 Views)
Hi kevin_khan,
I went ahead and tried to open it and got the error attached.
Peter T
Applications Engineer
Message 7 of 8
(6,469 Views)
Dear National Instruments,
Is there any solution to a "LabView load error code 1: LabView load error code %ld: %pā€" type error ?
/sĆøren jensen
Message 8 of 8
(6,032 Views)
