Allocate memory
Hi all, I am new to programming and I am studying LabVIEW myself. I wrote a Mathscript code on the block diagram, it runs properly and I saved it. But after I reopened the same code, and it can not run and it says "LabVIEW: Memory is full......" I checked the solution but I don't know how to allocate memory in LabVIEW. It's weird because I only saved few files.
I will really appreciate your help. Have a good day!
Message 1 of 9
(5,925 Views)
Message 2 of 9
(5,913 Views)
How large of an array are you trying to make?  If you try more than 2GB (or whatever Windows decides to limit you to), you get that error.
Message 3 of 9
(5,903 Views)
Thanks for the reply
Could you take I look at my code attached. Is it too large. I feel not.
Message 4 of 9
(5,861 Views)
here is my code in Mathscript version.
Message 5 of 9
(5,852 Views)
You need to learn how to do some computer basics and take a screen shot and make a snippet (look it up!) or attach the actual VI. No one can debug a fuzzy image taken by your phone.
Message 6 of 9
(5,831 Views)
My bad,  Here is my file. Thank you for  the help.
Message 7 of 9
(5,808 Views)
Accepted by zhan2854umn
What are typical input values ofr all the controls?
(For example if your "sample frequency" is zero, you'll run out of memory, of course.)
Message 8 of 9
(5,776 Views)
Oh I did not even notice😅. Thank you!
Message 9 of 9
(5,763 Views)
