All windows open when starting a touch panel application
I'm developing an HMI application for a TP-2512 using the TCP navigation VIs.  When I open the top level VI, whether on my PC or when I deploy the app to the touch screen, all of my views also open.  Looking through the help files, it seems like only the home/default view should open at start-up.  I have the SubVI node set-up options set to Show front panel when called and Close afterwards if originally closed.  Is there anything I can do to keep all of the other views from launching on start-up?
(2,577 Views)
John,
Can you go to File > VI properties on your subVIs and check your settings under Window Appearance > Customize. See whether Show Front Panel when Loaded is checked. Just to clarify, you said the subVI front panels get opened when you load your top level VI (as opposed to when you run it), correct?
Message Edited by mishkin on 04-06-2010 01:26 PM
Misha
(2,560 Views)
Thanks, that was it.  I had set the execution options, but I forgot about the appearance options.  It's always the simple things you forget.
(2,550 Views)
