I use low-end Advantech PCI card 1710HG with external socket card 8710. Included Advantech software does not suit me, so I have chosen LabView.
I found it difficult to measure temperature with those cards using LabView. However after installing Advantech drivers into LabView I found an information in readme.htm file: (C:\Program Files\National Instruments\LabVIEW\examples\Advantech)
Hi, if you have a look under the functions palette->Data Aquisition->Signal conditioning, theres a couple of .vi's that will take in a voltage from a thermistor, thermocouple or RTD as long as you know the spec of the transducer, it's great.
