Advantech Cards in LabView 6
Dear Sirs
I use low-end Advantech PCI card 1710HG with external socket card 8710.
Included Advantech software does not suit me, so I have chosen LabView.
I found it difficult to measure temperature with those cards using LabView.
However after installing Advantech drivers into LabView I found an
information in readme.htm file:
(C:\Program Files\National Instruments\LabVIEW\examples\Advantech)
PCI-1710
Adint Adsoft Adexp Counter Dasoft DigInBit DigInByte
DigOutBit DigOutByte Freq Madint Madsoft Pulse
PCI-1710HG
same as PCI-1710 and add Thermo example
i have not found any thermo example?
does anybody know what to do to avoid
writing fuction which would recalculate
voltage into temperature un
its?
Michal, Poland.
(3,185 Views)
if you have a look under the functions palette->Data Aquisition->Signal conditioning, theres a couple of .vi's that will take in a voltage from a thermistor, thermocouple or RTD as long as you know the spec of the transducer, it's great.
Have a look under the thermocouples examples too.
Hope that helps.
S.
// it takes almost no time to rate an answer Smiley Wink
(3,185 Views)
