Advanced Format String to show mA
Hey,
I have a display in my program thats show the current measured using a SMU, I want that display to show mA instead of A.
Example
.00548 A
-> 5.48 mA
Or
5.48E-5 A
-> 5.48E-2 mA
Anybody know how this can be accomplished?
Is there a specific Format String i can use in data display?
Message 1 of 11
(3,898 Views)
Which kind of indicator are you using to display the value in mA? Is a numeric indicator or a string?
Ricky
Italian Developer engineer
www.www.selt-sistemi.com
Message 2 of 11
(3,891 Views)
Hey,
It's numeric indicator that I want to display mA.
Message 3 of 11
(3,887 Views)
Like this?
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 11
(3,883 Views)
Hey,
Im running Labview 8.5, could you save it for that and repost it please.
Message 5 of 11
(3,877 Views)
look at this....
Ricky
Message 6 of 11
(3,871 Views)
Hey,
This is handy but, the problem is that i have Amps and need to convert them to mA, then display them.
Is there an easy way to do this (ie a format string) or will i have to alter the value before i display it?
Message 7 of 11
(3,862 Views)
Sorry but I didn't get you! You simply have to transform the data in mA so, why don't you want to multiply the value per 1000?
Ricky
Message 8 of 11
(3,859 Views)
Try This:
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
Message 9 of 11
(3,852 Views)
It seems to work very good!
Ricky
Message 10 of 11
(3,845 Views)
