Address of array changed by for loop
Hi
I am creating a VI that initialises an array in a for loop. The array is used by a DLL and I am finding that the address of the array is different outside the loop. The attached example illustrates this. The GetAddress function simply displays the address of the array passed to it in a message box.
Does anyone know how I can ensure that the address is not changed?
Robin
(3,551 Views)
Because LabVIEW is data flow oriented, it makes copies of arrays, because it doesn't know how they are going to be modified. Because you have a wire branch, it's probably making a copy. Turn on Show Buffer Allocations in the Profile menu. The copies contain the same data, so no worries about that.
(3,545 Views)
LabVIEW MUST make a datacopy of the array at the wire branch, because it need to ensure that the loop output tunnel, which is wired directly from initialize array (!), does not contain data updated from inside the first dll. If the dll were allowed to step on the data of the output tunnel, all bets are off.
If both instances of the dll should operate on the same array, you need to wire it differently. For example you could try and delete the wire branch and wire from the output of the first dll to the input of the second dll.
What are you actually trying to do?
(3,520 Views)
Hi
Thanks for the replies.
I should have realised that it is the branch causing the data copy.
I have a DLL that assigns a set of data buffers using one function and populates them using another function.  The assign buffer function is called once for each buffer and the populate function is called once only.
If I assign all of my buffers in a for loop, I get a 2D array by using an auto-indexed tunnel. However, when I call my populate function, the arrays remain unchanged. This appears to be because the location of the arrays has changed since the call to assign the buffer.
Does the auto-indexing tunnel move the locations of arrays so that they are contiguous? Is there a way to preserve the address that was allocated by the initialise array block and still combine them into a 2D array?
Robin
(3,484 Views)
In LabVIEW, all arrays are contiguous in memory.
I am sure your problem can be solved. Could you provide a bit more details or example code?
(3,471 Views)
Wrapping the dll call in an Action Engine wrapper, I believe will met your req's.
The Shift Register will "hold" the data when the dll is not being called.
Ben
(3,467 Views)
