Adding video to a data view
When I try and add video to a data view, the video will not play.  The following is what shows up in the display window (see attachment).  The number of frames and frame frequency are completely wrong, and the number of frames is a non editable field.  I am converting the file to an AVI.  This video also works fine on my co-workers PC.
(3,636 Views)
Hi spickman,
I was wondering if the videos that ships with Diadem also cause the same problems. Also, what version of Diadem are you, as well as your colleague, using?
Hassan Atassi
Director, ni.com
(3,593 Views)
The videos that ships with Diadem do work.
My colleagues and I are all using the same version, Diadem Advanced. Attached is the version info.
(3,542 Views)
Hi Spickman,
It seems there is something fishy going on with the video file.  Would it be possible to copy the working video file from your colleagues computer to yours and trying it out.
Also, I noticed you posted this question on the LabVIEW forum.  For future reference, there is also a DIAdem board where you can post your DIAdem specific issues.  This way they get more visibility in the right place.
Hassan Atassi
Director, ni.com
(3,512 Views)
We tried the identical video from the same location......
(3,494 Views)
Hi Spickman,
Can you try copying the .tdv file from your coworker over to your computer and see if that works?
Hassan Atassi
Director, ni.com
(3,460 Views)
