Adding time delay in Signal
I am actully trying to create a time delay in a signal and then later on i want to apply an algorithm to find TDOA between the signals originated from a single signal source.They have relative phase difference and I have tried to model a VI so that i could see the signals visually and analyze TDOA analytically first then ensuring the proper working of Algo.Currently I am unable to visually differentiate between the signals having different phase on single indicator.I am seeing only one waveform.I want to see both ....
(3,284 Views)
Accepted by sets
Hi sets,
Right click your appended array plot and go to the "Scales" tab.  At the bottom of the "Scales" tab, make sure that the "Ignore waveform time stamp on x-axes" is unchecked.  The t0 parameter on the "Build Waveform" function is a timestamp datatype.  If that "Ignore..." box is checked, the graph uses the indicies of the Y values, which always start at zero.
Note that the waveform generated will have a set number of samples and that changing the initial timestamp shifts all of the samples.
Let me know if you have additional questions!
(3,254 Views)
thankyou Smiley Happy
(3,203 Views)
