Adding noise and waveform
I'm trying to make a VI that shows how certain types of noise affect a signal. The result is not what I expected, any comments or recommendations to make it better? attached below is the vi
(7,800 Views)
What is not meeting your expectations? And in what way?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(7,791 Views)
I was expecting a signal looking more like this
(7,787 Views)
Accepted by topic author meere
Use the Signal Processing->Waveform Generation VIs for your noise generation.  They should use the same sampling info as your main signal.
(7,764 Views)
What operation did you use? that addition vi seemed different from thte one I used.. thank you for the help
(7,757 Views)
The Add will show the error terminals when two waveforms are being added together.  You will get an error if the data rates are different.
(7,742 Views)
