Adding new variables to subvi
After importing my DLL LabView import wizard kindly created Vi-s for me, i specified which variables i want to be shared or not.
I also have the main vi where i use all my DLL functions as subvi-s
I manually added a variable in the subvi that i want to receive in the main vi (i want subvi to do some stuff apart from just containing my DLL function I/O)
I make it similar to my function output variables. But when i add this subvi to the main vi i still see the same amount of terminals on it.
How do i properly create a variable in subvi which i can access from my main vi? Am i doing something wrong? I thought i need to reconfigure the subvi to specify new variable accessibility, but i couldn't find a way to do it...
Thanks in advance!
PS I'm new to LabView and i don't know it that good yet, it takes time to find things i need because i don't know where they are...
Message 1 of 9
(4,973 Views)
Hi Kitt,
Are you talking about in/out values, connected in the ConnectorPane of your subVI?
(LabVIEW doesn't use "variables" in the sense of textual programming.)
I don't know. You didn't attach any code…
Message 2 of 9
(4,959 Views)
Did you learn how to use the Connector Pane yet?
Message 3 of 9
(4,956 Views)
I make it similar to my function output variables. But when i add this subvi to the main vi i still see the same amount of terminals on it. (My output var does not appear)
Thanks in advance!
Message 4 of 9
(4,955 Views)
Hi Kitt,
please stick with your thread instead of creating a new thread for the very same topic!
(Especially after you got the first responses.)
Message 5 of 9
(4,943 Views)
I'm sorry, Chrome bugged out, could not create the thread for some reason (please try again in a few minutes), maybe it created several threads or smth...
Message 6 of 9
(4,933 Views)
Yes, exactly. Now i know how this thing is called at least so i can go and learn how to use it properly. Maybe you could tell me how to deal with my specific problem to save me some time?
Offtopic - Captcha makes me sick already. Cant reply to the message for the fifth time. "Error: verification failed"
Six. This website hates me.
Message 7 of 9
(4,921 Views)
Accepted by topic author K_I_T_T
Hi Kitt,
Learn about using the connector pane.
It is explained in the LabVIEW help (there's a "basics"/"first steps" chapter) and in the Training section in the header of this LabVIEW board…
Message 8 of 9
(4,914 Views)
Ok, I will
Thank you for your patience and help
Message 9 of 9
(4,910 Views)
