Adding data points to multiple plots at once
I have a source that generates between 1 and N (here 5) data points per update. I would like to create a vi that will put generated point 1 in graph 1 generated point 2 in graph 2...ect
I'm not sure why, but my XY Graph clears every few updates. If someone could help me solve/optimize, it would be greatly appreciated.
True CaseTrue Case
False CaseFalse Case
(3,698 Views)
Accepted by ATE-EGNE
Each element of your XY Graph data is a single plot. When you "receive" your data, you keep working on the same plot due to your index array, which is probably not a valid index. If your For Loop runs 3 times because the size of the array is 3, then you will try to work on the 4th plot (because 0 would be the 1st plot) which doesn't exist.
(3,681 Views)
SolvedSolved
You are correct. Pesky LabVIEW doing what I tell it to and not what I mean
(3,661 Views)
I like to use the in place element structure, just to make it a little more obvious what is going on.
(3,655 Views)
I was under the impression from this post that the in-place element structure was no longer in the meta (for lack of a better term XD )
(3,647 Views)
The consensus from that thread is that you probably don't need to use the IPE for performance gains because the compiler will try to do most of that behind the scenes.
However, there are definitely still use cases for the IPE. If you are accessing a DVR you have to use it. I think it makes the above situation look clearer on the block diagram, which the compiler will not help you with 😊
(3,643 Views)
Ok, I understand now. thanks
(3,611 Views)
