Adding a picture
Sorry, I am brand new to labview and trying to add a basic picture to
my form and then move it across the screen. I haven't been able to
figure out how to add a picture so any help on this subject would be
much appreciated.
(3,215 Views)
Could you explain what you mean by form? This is not a known LabVIEW term. (... add a basic picture to my form ...).
  1. Do you want to display a picture in a picture indicator?
  2. Do you want to add a background picture to the pront panel?
  3. Do you want to customize a control (button, slider, etc) with a picture?
  4. ???
Message Edited by altenbach on 03-17-2006 07:46 PM
(3,209 Views)
I would like to add a picture to my front panel. I have no clue what a
picture indicator is
(3,202 Views)
You can move the position of front panel objects in LabVIEW, so if you put a picture in an object, you can simply move the object.  A picture control will allow you to input and modify a picture, afterwhich you could change the origin so that the picture moves within the picture control.  Of course, you could always move the whole picture control as well.  I have attached a VI which shows both methods - it is a modified version of an example program.  Move the sliders and you'll see the idea - one set of vertical/horizontal sliders moves the picture within the control, and the other set moves the entire picture control itself.
I hope this helps!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,167 Views)
