Add paths in an array
I have to open different .bmp-files, which are in different folders. On the screenshoot you can see how i realised it after got some tips in the forum. Now my problem is, that i would like to add the paths in an array from which i can later on get the paths of the bmp and create a avi. I tried different solutions with the array functions but each rewrite the paths and didn't list them after and after. Some ideas how to manage?
(3,233 Views)
The problem is with your for loop. In the first place, you would want to initialize the array outside the loop and pass it through the loop using a shift register. That way, you'll always be working on the same data and not  on a new array each time. Also, you would want to use Replace Array Subset instead of Insert Into Array.
In any case, it would be much simpler to simply do this:
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
Message Edited by tst on 09-13-2006 12:53 PM
___________________
Try to take over the world!
(3,226 Views)
