Add object into JSON file
Maybe it looks like a silly question, but I have just started to work with JSON files (I have never worked with them before). I'm trying to add an object (I don't know if this is the correct term) into a JSON file already created, but the new object replaces all the others of the same item.
(4,164 Views)
Accepted by vicens
You could get the array elements and concatenate like this:
(4,130 Views)
Note: in the latest available versions of JSONtext, one can use [#] to indicate a point at the end of an array for insertion, so one can directly insert using the path "$.users[#]".
(3,885 Views)
