Add new item to OPC server in LabView
Hi. I want to connect my PLC Unitronics Jazz to LabView using OPC Server. It have OPC Server called UniOPC Server. I don't know how to add an Item in LabView.
UniOPC don't have option to add new Item - I have to do this by opc client. In OPC QuickClient I can see UniOPC server, and there I can add Item and change values of variables (for example I can change value of MB0 - Memory Bit 0) but in LabView when I try to use this in VI project I have error: "Error 0x0000002A connecting to .../plc.MB0".
I would like to try to add new Item without QuickClient - in LabView and see if that works. Can someone help me, please?
(3,119 Views)
Hi there,
According to the following link, you might not be able to connect your PLC to LabVIEW:
https://www.ni.com/en/support/documentation/supplemental/07/supported-device---driver-plug-in-list-f...
In general, if you would like to establish a connection between LabVIEW and a PLC, here is a step-by-step guide:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0MPCAY&l=en-US
Norbert
(3,076 Views)
