Add extra input into custom VI
Hello. I hope someone can help me. I have a simple custom VI, where inputs x,y, and x2 are given and then output x-y and inside some operation. How is it possible to add x3 for example, so there will be additional input , without creating this structure all over again and making custom vi? Basically how to modify existing one? Thank you
(1,034 Views)
i'm not sure if I understood your questio, my version is older than the file you postted so I wasn't able to open it, but to add another input you insert a control (input) into your vi, then you need to assign that control into the terminals of your icon.
(1,029 Views)
How to assign it into terminals of my icon? I didnt get it
(1,026 Views)
Hi Samchuk,
Read the LabVIEW help: look out for "connector pane"…
(1,020 Views)
Creating Sub VIs in NI LabVIEW (youtube.com)
Create and Configure a LabVIEW SubVI
https://tmesystems.net/
(984 Views)
Probably this animation will help you:
(970 Views)
thank you so much
(956 Views)
