Add Items in combo box at runtime
In my program, I want to add int "34" "43","17"...... and let user choose one of them from combo box. How can I add such items in combo box at runtime. Create a property node "String[]"? I try that but its display is "3443". I wanna to display like "34"
        43
        17
Message 1 of 11
(10,877 Views)
Did you wire an array of 3 elements to the property node? A string with linefeed wont do.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 11
(10,872 Views)
Accepted by song403
See attached snippet
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 3 of 11
(10,862 Views)
In my program, I fetch data one by one. first, I fetch 34, second, I fetch 43 and so on. So I want to add item one by one also. but  I can not link string to string[]. So how can I do?
Message 4 of 11
(10,833 Views)
Hi song,
collect your strings in an array and wire the array to that property node.
That's how it works!
Message 5 of 11
(10,824 Views)
Accepted by song403
Seeattachedsnippet,itmayhelp.
With Regards
Miraz
Message 6 of 11
(10,819 Views)
Accepted by song403
Just a small tip.
Adding Strings[] is probably not ideal unless Values = strings property is true and I can't tell if it is from the OPs question!  Better practice is to use the Strings and Values[] property and add both the string and the value
"Should be" isn't "Is" -Jay
Message 7 of 11
(10,804 Views)
Accepted by song403
One more question. How can I clear items from combo box when my program start up. use another property?
Message 8 of 11
(10,771 Views)
Accepted by song403
Hi song,
use the very same property - and wire an array only containing the strings/values you need…
Message 9 of 11
(10,739 Views)
Accepted by song403
If you want to clear the contents of combo box, just create array constant for the same property node and do not include any element in that array. (empty array)
With Regards
Miraz
Message 10 of 11
(10,730 Views)
