01-13-2021 12:40 PM
I am trying to build an application to interact with a cRIO. When running it on the development machine everything works fine and if there is an error I get an error message from simple error handle:
However, when I run the application on the target computer I get that the error code is undefined.
How can I "teach" my application the error codes from the module? The module I am using is SoftMotion, but the problem is probably not limited to that.
I also tried adding Soft Motion Run time to the installer, but that wants to be activated. I also don't need SoftMotion to run my Windows application, so I'd like to leave it out if possible.
Any help is appreciated!
01-13-2021 01:14 PM
The error is actually being reported correctly, but it occurred at an unidentified location. I misread it the first time, also, because you almost never see the "unidentified location" message. It it's "un-something", it's almost always "undefined".
I'm sot sure what it means when running on a target, but in development mode, it means the VI where it occurred only exists in memory - i.e., it has yet to be saved to disk.
01-13-2021 02:24 PM - edited 01-13-2021 02:26 PM
Oh, sorry. It didn't attach my second screenshot, which is what this is actually about:
So as I said: It seems that my application can't interpret the error code. How do I include it in the exe or installer?
P.S.: The unidentified location is only because I just connected an error cluster and didn't fill out the soruce string.
