Add Class Specific Target to a Project Programmatically
I'm trying to create a vi which can programmatically create a project and add a target device to it (PXI-7954R). Currently I'm having no problems creating a project and adding a FPGA target to it, but it isn't class specific i.e.. Its not the 7954R.
I've found a really horrible way to do it by opening up the project file as a text file and picking through and adding what needs to be added (looking at a already created project with the target in it to compair).
Does anyone know of a way to add a class specific target to a project in the labview environment without having to manually change the project file?
Any help would be very much appreciated
(3,313 Views)
Accepted by James Hall
Hi James,
You need to add the correct Class ID into the Project Item Type terminal.
You will then have to create and set the correct Tags associated with that Item.
Please See Attached,
Steve
Message Edited by SteveBale on 02-24-2010 03:45 AM
(3,310 Views)
