Actplot errors!!!
Ok As you can see in my VI, when you run the vi, the data will be plotted in the chart. However, when you try to change to value in the main array, nothing happens in the charge even though the value has been changed. So the plotted lines don't follow the change of the values in the data mainstream.
P.S. I couldn't see the option to cancel the marked solution. I don't know where it is
Message 11 of 11
(532 Views)
