Actor Framework UI Communication
@McQuillan wrote:
I tried to comment a while ago, but there were some "technical issues" so I'm not sure if it got posted (sorry if this is a repeat!)
I've been using this toolkit from MGI and I really like it:
http://www.mooregoodideas.com/products/panel-manager/index.html
When using AF for a UI it is very common to use subpanels. I love them, they make for a very clean UI, I've implemented my UIs with drag and drop between several subpanels. The toolkit I linked, makes it very easy to manager all the subpanel references.
When you install the toolkit, it comes with come examples to get you started Smiley Happy
MGI toolkit aside for the moment (I'll revisit that later), is it pretty clear cut that to insert an Actor Core as a subpanel, you need to create an actor tree similar to the following with a few helper classes? Namely, create a parent actor that will be insertable and acts as a proxy with the helper classes?
https://forums.ni.com/t5/Actor-Framework-Documents/How-to-Embed-a-Nested-Actor-s-Front-Panel-into-a-...
Message 11 of 13
(1,340 Views)
Do you need to? No. Should you? Yes - Allen Smith is a very, very good programmer, and I believe one of the writers of the actor framework. Probably a good idea to listen to him.
Message 12 of 13
(1,327 Views)
I have incorporated that example into my code with a few modifications, and it works really well, easy, and mostly transparent. Consider the advice heeded!
Message 13 of 13
(1,320 Views)
