Communication ModBus TCPIP Error 6004
I'm getting error 6004 Modbus Exception code: 4.
I'm trying to connect to  a Beckhoff BK9050 with 16 output KL2809 and 16 inputs KL1809.
I used a VI from the Modbus library (MB Ethernet Example Master.vi).
When I start, everything seems to work. I can control the outputs and I can read the inputs in my program.
But when I stop the program and start it again, then the error 6004 exception code 4 arrives when I will control an output. What can cause this problem?
Thanks in advance for the support.
(7,856 Views)
(7,857 Views)
Modbus exception 4 is an error within the slave device.  It couldn't do what it was asked so it is responding back with that message.
It is not a problem with your LabVIEW code, but a problem with the slave device.
You'll need to contact Beckhoff for help on that.
(7,819 Views)
Accepted by topic author Willem1978
Thanks for your reply.
I have solved the problem.
The problem was that the Beckhoff module had a Watchdog error when I stopped my VI.
Now I reset the Watchdog Timer just before I close the VI by transfering 0xBECF and 0xAFFE to register 0X1121.
I got it from http://forums.ni.com/t5/forums/v3_1/forumtopicpage/board-id/170/thread-id/518237/page/1.
(7,816 Views)
Hello RavensFan,
I am trying to communicate with Oriental Motor using Modbus Protocol. But I am getting 6004 Error.
Is it because I am sending the command Incorrect?
Thanks & Regards,
Bharath Kumar
GCentral
(6,545 Views)
All we can see is your front panel.
But one thing I see is that you have "Write Single Register" but the quantity to write is set to 2.
(6,539 Views)
Hello RavensFan,
Thanks for the reply. Sorry I did not attach the VI. I am trying to drive Rksd507-cd Driver from Oriental motor by modbus. Learning modbus. and looking for more examples. Any library will be helpful.(Oriental motor with LabVIEW is so hard):smileymad:
any link to modbus example will be helpful(Communicating with adam4561 serial converter).
Thanks & Regards,
Bharath Kumar
GCentral
(6,530 Views)
