ActiveX writing to Word ActiveXControl - Textbox
Does anybody know, if it is possible to write from LabVIEW via ActiveX or the ReportGenerationToolkit to a Word - Control - Textbox.
I have attached a Screenshot from the Wordfile and the Word - Testdocument.
I can't find any Solution until now. I can't adress such a Textbox with a simple bookmark. It seems that this object type is a Microsoft Forms 2.0-textfield.
I assume, that I need to load Microsoft Forms 2.0 Object Library Version 2.0 for this Object Type.
But I have no idea how I can send some text from LabVIEW to such a TextBox, because I also have to open the document which I do with word_Application Reference.
It would be very helpful if anyone has an idea or a example - solution how it would work.
Thanks very much!
(2,369 Views)
I'd look into the  SendKeys.SendWait  function of the System.Windows.Forms namespace. Look into that.
(2,329 Views)
Yes. This is an annoying thing. Here's the issue:
Cannot Access Methods or Properties for Microsoft Office ActiveX References - National Instruments (...
Solution, browse for:
<Excel> --> C:\Program files\Microsoft Office\root\officeXX\EXCEL.EXE
<Word> --> C:\Program files\Microsoft Office\root\officeXX\MSWORD.OLD
(2,324 Views)
Accepted by topic author Steiner_Wolfgang
I have now solved  the described problem.
You have to search in the word document for InlineShapes (ActiveX Controls like Textboxes or Checkboxes are in a word document from Type InlineShape)
There you have to select OLEFormat where you get the classtype and the objectreference.
Then you have to convert the Variant - Object to the Class you need. In my case I have to Load Microsoft Forms 2.0 Object Library Version 2.0 and the Object TextBox (Forms.TextBox.1)
Then you can write to the TextBox.
I have attached my Example File (for LV20 and also for older LV15) if anyone else needs also a solution for this case.
Thanks anyway to everyone who has already replied and tried to help to find a solution!
(2,276 Views)
