ActiveX methods context-sensitive help error
On the pop-up menu of an ActiveX method in my LabVIEW diagram I select the "Help for MyMethod" and get "the topic does not exist ..." error 129. The menu item references a Winhelp 4.0 file that I created. Editing MyHelp.hpj with MS Help Workshop, I tried mapping MyTopic directly to a topic number, then using an Alias, then prefixing the TopicID with "IDH_". Nothing works. What TopicID is Labview 5.1.1 looking for? Does anyone have a fix or similar experience?
(3,132 Views)
This document is from the MSDN library and adresses how to add context sensitive help to ActiveX controls.
(3,132 Views)
Aaron Marks wrote in message news:<50650000000500000028490000-1003545641000@exchange.ni.com>...
After reading your referenced attachment I was able to cobble a fix. **** Thank you!
(3,132 Views)
